Renault Megane 02 plate
13 Dec 2007
Yorkshire
hi
looking for help and a littel advice. i have a renault megane o2 plate that for no apparent reason has started to run very uneven ( shuddering when ticking over and running unevenly ) also the engine managment light is on, the only previous problems I have noticed is a little miss or a slight flat spot when accelerating
14 Jun 2006
Surrey
Yep, as above.
To trck down the faulty pack, unplug the multipin plugs which go to the coils one at a time. whne doing 3 of them the engine will probably stall, when you find the one that makes no difference to the engine revs, you've found your knackered one.
We're around £50 from renault last time i got one, but try gsfcarparts.com as they're probably doing them now
3 Sep 2006
Cheshire
Check the number burnt into the rest of the coil packs, if its 401 or below replace them as they will fail!
