I have a Potterton Suprima 40L (8 yrs old) fitted in my house. It seems to have the well documented intermittent Lock-out problem. The boiler can work perfectly for a week or so and then fail everyday for the week after. Usually after it been running for 10 mins or so the boiler will go into standby (green flashing light) when it a tries to relight it fails and locks-out and pump keeps running. Resetting it sometimes works first time or can take several goes.
It was looked at by a boiler engineer, who checked the stats and boiler itself, but come to the conclusion it is most likely the PCB. His recommendation was to replace the boiler rather than repair it (repair being approx £300).
1) Does the above sound like it is most likely the PCB?
2) If repaired what is the likely life would the boiler have before another failure?
3) The boiler is currently housed in a kitchen cupboard, supplying CH and unvented tank. What boiler would be a good recommendation if to replace?
Thanks in advance for any advice
