Waste oil is slightly different to veg oil.
Waste is synthetic or non synthetic,clutch, break, engine that sort of oil
yeah like i'm gonna belive anything you say
stop arguing with god
As for the ATAG,its absolutely no more efficient than any other boiler during CH demand,what it is however is more efficient during hot water production.As the hot water production is probably a 1/4 of a combi boiler running period is that such a great saving when it only increases its efficiency by 5-10%.
As good as it is its still not 100% efficient.
Having to fit a Zenex to an existing band A boiler is a waste of money,last time i looked the zenex was £700ish quid
Lets look at the alternatives,solar waste of money waste of time,free hot water at a ridiculous cost during the high sun periods,no CH effect during winter when its needed and little effect on DHW.60% saving max on DHW production.
GSHP under water, seen plenty done wrong(frozen lake in summer) and some done right,but not many folks have a lake in the garden.
GSHP slinkies,wouldnt install one, seen to many that have failed through excess heat extraction even when laid at the manufacturers requirements.Lay flat is better but requires more room,gshp is 25M2 per KW.
ASHP,weve said enough already. High efficiency 3-400%,but are limited by the refridgerent.Mitsi,daikin,Sanyo all worth a shout,ignore boiler manufacturers units,most cant build gas boilers that well let alone something that A/C companies have been doing for years.
CHP,limited by manufacturer,still gas driven but produces elec,sell back or utilise its up to the user.the proposed feed in tariff changes might see it become domestically viable.Products at present Baxi ecogen,Whispergen,EC power.
Installation costs will always favour NG boilers if you have NG,but running costs of renewables will save in the long run,it just depends how long you intend to stay.
Having actually compared costs on site between various systems in comparison to a 100%eff gas boiler,i know which way id lean.Most easily accesable products ASHP/GSHP/CHP have caught the differnece between installation and running up within 5-8(dependent upon product),after that your saving so if you have a 10-15 year plan......
Lee
In relation to comparative running costs,we've done actual comparative studies on an actual site,so have many other companies and manufacturers.my claims are no different to anyone elses with industry experience in these fields.
As good as atag is it's still limited in efficiency.regardless of asho/gshp/chp manufacturer NG has no future.
Let's look at the code for sustainable homes,come 2016(code6) nat gas won't web be an option.all new builds are rated over a 25year payback plan. The coding is based on savings and runnings, read through what savings you achieve when fitting renewables compared to band a boilers.
Atag ec as a stand alone boiler is probably code 3.
As for what atag's can do in comparison to other boiler,you don't have to convince me.I've got an atag at home,I'm just finishing the solar preheat to it through an intasol valve.
vulcancontinental
You said: "if a radiator had an efficiency of 100% the return would be leaving at room temp." I misread this as flow temp.
Where did I say that? I think it's must be your turn to misread.Your comment about rads picking up heat from the room when cold
Is perfectionist a rep for ATAG?
