Ok, I just want to check I'm not going completely loopy...
A while back I bought a "Cooke & Lewis Shaftesbury Keyhole Acrylic Bath" from B&Q along with the appropriate panel.
I've now (finally) got round to the point of trying to fit it. It comes with the bent tubular legs that fit and screw into the underside of the bath, and then 5 adjustable feet, (black plastic feet on a section of threaded bar, with 2 nuts).
I'm setting the height of the bath so that with the side panel fitted everything sits at the correct height.
HOWEVER, setting the bath like this means that after fitting the pop-up-waste (supplied with the bath) to the bath I have just 40mm gap left to fit the trap, (so I'm going to have to cut into the floor).
Also the threaded bars on the adjustable feet are too long. When setting them so that the bath is the correct height for the side panel there is so much bar not being used that it then pushes against the actual skin of the bath on the four corners. The fifth foot that is supposed to be fitted to the center of the bath won't even fit under the bath due to the length of the bar on the adjustable foot!
Am I likely to have done something silly here, or is it 'normal' to have to cut down the threaded bars of the adjustable feet? I'm wondering if they just supply a generic pack of adjustable feet for all baths, and haven't allowed for this bath? (Actually, I can't see how the center foot would fit under ANY baths without being cut down...)
TIA[/url]
TIA[/url]
