Single pipe heating quandry
9 Oct 2010
Evening all.
My one pipe central heating has been bugging me for a while now.It works ok downstairs.But upstairs new radiators were fitted sometime before we moved in and were not installed correctly.There is no bypass for the hot water to flow through if the radiators are shut off meaning that all the rads upstairs go cold if any one of them are isolated.It also means that the radiators at the end of the upstairs circuit (We apparently have 2.1Upstairs and 1downstairs) struggle to get any heat in them at all even when all rads are fully open and pump up to speed 3,as the hot water has to pass through all the upstairs rads before finally reaching them.
Now i've spoken to a few plumbers and i've got two options.Rip the whole lot out and install two pipes.Sounds good but my bank balance doesn't agree.
Or.Get bypass lines fitted across each upstairs radiator for a fraction of the cost.I have been told that this may not rectify the problem as the hot water will always try to travel along the bypass first instead of through the rad.Anyone know if this is true? The rads downstairs are similar to the ones used to keep jesus's manger warm.They are ancient and the feed in and out are situated in the middle bottom of each one!
Sorry for dragging this out.
Any advice very much appreciated.
Cheers
When installing a single pipe loop the radiators should be piped Flow into a top connection on the rad and the return from a bottom connection this way you promote a gravity circulation through the rads the pump will only circulate water around the loop, so this gravity action is essential :wink:
Evening all.
My one pipe central heating has been bugging me for a while now. They are ancient and the feed in and out are situated in the middle bottom of each one!
Cheers
I ve seen those once :idea: that single feed underneath is designed specifically for a 1 pipe system - as a money saving idea :roll: With your normal ones upstairs, you are going to have the Devil`s own job getting any sort of balance in the system :cry:
So that's another thing the pillocks who first installed the heating got wrong.
I might just move.
