Baxi solo 15HE air lock problem
24 Apr 2010
Devon
Had to install another radiator, so drained the system and installed the radiator. This went fine.
Refilled the system, which took a long time, finally managed to get the air out the radiators and the pump, but the boiler sounds like its constantly filling with water when either the hot water and or heating is on.
It sounds just like a tap running ! Dont remember whether this was like this before or not.
Is there a bleed on the boiler itself, or is this something that will eventually bleed its way out.
Many thanks for your advice in advance
Rob
Most heat only fits include a drain cock on pipework just above the boiler.......try backfilling system with hose connected to a tap be careful not to overfill !
I don't beleive this is good advice, although it's fairly regular on this and other forums. It is a last reort, and you should first determine the cause of difficult filling.
It is also potentially disatrous for a diy'er
Did you bleed with pumpon or off?
The pump was on.
I think the motorised valve could have been closed for the heating and open for the water, which will explain the long time in trying to fill.
I have looked above the boiler, and taken the front cover off, but cannot see what obviously looks like a drain valve.
Rob
The pump was on.
wrong answer
wrong answer
But predictable
Drain system again, opening all rad bleed valves. Close rad bleeds. Refill with motorised valve(s) manually open, and pump OFF. You will probably find it will fill faster. Bleed rads, staring from bootom and work your way up.
Let us kmow how you get on.
Thanks for the replies.
How do i manually open the motorised valve ?
Or could i make sure its running the central heating and then shut the boiler off and turn the water off, this way it will be open for the central heating.
Sorry if its sounds like i dont know what im doing, but for the last 18 years we have always had a combi boiler (which was simple)
Just one other thing, will it do any damage leaving it as it is for a couple days, as what with work im probably not going to have time till the weekend.
Rob
