Hi there, I have posted about this problem before but now the issue has come to a head.
I'm converting my windows in the lounge into french doors.
I have noticed a hairline crack in the middle of the lintel about 4.5" high going up on the face, it goes underneath and the back of the lintel. I believe this has been caused by drilling into the lintel and inserting wooden dowels for the curtain rail.
Asking you professionals would this be a concern? (See Pic 1&2)
Would you replace?
The lintel dimensions are L2040mm H200mm W115mm, it also isn't level, slight slope.
Also outside the course of solider bricks there isn't a lintel at all. The course of solider bricks has cracked and is now resting on the window.
Today I very carefully inserted a steel chisel, gave a little wiggle and the bricks slumped by 5-6 mm (GREAT). A lintel is a given here!!
Asking you chaps.
Would/should i replace the internal load bearing concrete lintel??
Sorry for the long message, just giving as much info as possible.
All help will be welcomed
Would you replace?
Asking you chaps.
