I
imamartian
I recently fitted a sink in my downstairs loo.... the sink is small but i have problems with it being securely fitted to the wall.
It is fitted with two metal brackets... from the front they are normal rectangles... and from the side, if you imagine a capital Y and delete one of the two upper up rights (?)... you have a metal plate to screw to the wall and a slot where the sink sits... Problem is that the metal is quite flexible, and if you lean on the sink, the leverage means the sinks moves quite a lot, so you can't seal it against the wall, and the plumbing seems to be playing a part in the support which is not good.
There are also two screwholes, but they are at the bottom of the wall, so add no further support...
Have i missed sommat?
Ta.
Ta.
