Making good around patio doors
1 Nov 2010
Devon
We're at the stage of wanting to decorate the lounge in our new house. The previous owners had uPVC patio doors installed/fitted and, as seems the norm in this house, the installer used wide strips of uPVC to cover the damaged plaster/joins.
I plan on removing these and making good the missing areas but from what I can see the gaps are huge - 2-3 inches wide and the full height. The frame has been fitted to the outside course of the cavity wall and the cavity itself will be/is open.
What is the best way to bridge the gap and make good the internal plasterwork? What should I use and how do I go about filling such a large expanse? Will I need any metalwork to act as a base for whatever I use, I'm assuming I'm going to need far more than just plaster. How deep should I go (sideways) into the cavity? I'm bridging the cavity, do I have a problem in the making?
I didn't have this is my last property, the windows were made good without the need for the extra uPVC to bridge/cover up the gaps so I have no experience in this. Any/all help and advice welcome.
Kim
Kim
sand and cement pva first if gaps realy big use bits of brick plaster after
or get a bag of hardwall, wet the wall down first, then fill it with the hardwall, when it sets to a cheesy firmness, scrape/cut it back a couple of mm then use easifill to fill it flush with the existing wall and sand it smooth.
