The whole consumer unit is fixed equipment but is nevertheless notifiable because the AD specifically says it is. The AD could, but does not, say that an MCB change is notifiable.
Moreover, there is a very significant difference between a consumer unit change and an MCB change. You can isolate the connections to the latter with a switch; you cannot normally isolate a consumer unit with a switch.
OTOH you could replace a CU and copy it device for device and not create any new danger, but if you change an MCB for one of a different rating you could create a new situation which has lethal implications.
Indeed not. It is intended to explain the law to non-lawyers. As a non-lawyer, I comply with the AD even it it appears to contradict the law, because I'm not trained to interpret the law.
The issue is "can I change an MCB for one of a higher rating without notification?", not "Is it safe to change an MCB for one of a higher rating?". From what the OP says, it's safe to do so in this case.
How can he tell? There is a 16A breaker protecting a circuit that appears to be run in 16amp. That is unusual. Why do you think that might be?
Maybe there is a piece of 2.5mm cable spliced into the middle of the run, how can you tell?
Maybe the EFLI is too high to support a 32or 40amp CPD. How can you tell?
The OP certainly does not have the equipment to test this. The CPD cannot be upgraded unless this is done.
