Hello, I'll try and describe my problem the best I can, its a bit of a weird one. A few years ago I had my house re-wired and in order for the kitchen to be done we had to remove the ceiling to gain access. Its part of a single floor extension so removing the ceiling was cheaper than removing the felt roof.
When the new ceiling was been fitted I told the builders that I was fitting down lighters and asked them when fitting the fibre glass insulation could they leave spaces where the down lights would be fitted to prevent a risk of fire. However in their great wisdom they decided that rather than leave spaces they would just not insulate at all between these joists. It has now left virtually a 3rd of my kitchen roof without insulation!!! Its like insulate between 2 joists then skip 1 then insulate between another 2 then skip another one, so on so forth!!!
Can anyone give me any advice as to how I could possibly insulate these areas. The only access I have is though the 60mm holes where the down lights are fitted. The ceiling as approx 3m wide with 2 downlights spaced a metre apart. I know theres a severe draught coming in here as you can feel the wind blowing down the holes when the lights are removed.
I had thought about fitting a long tube to a can of expanding foam and then spraying it up. I have a mini IR camera which I can use to see what i,m doing which will help alot.
If anyone has any better ideas i'd love to hear them.
Davy
Davy
