I replaced my HW cylinder earlier this year, now we are using the CH more, I've noticed that the radiators are much colder when the HW is on. (i've also replaced/added some rads too)
Question 1:
I assume I need to properly balance my HW as it's stealing too much flow?
(I fitted a gate valve on the HW return so can balance it)
Question 2.
Just wanted to check if this is a definitive method for balancing your CH as I've seen other methods on the web so not sure: http://www.diynot.com/wiki/plumbing:faq:faq2
I assume I would do the rads as described, then the HW?
Question 3.
Reading the manual for my boiler it says it is "designed for a 20c differential accross the heating system"
Should I therefore balance my rads/HW to have a 20c drop?
If it helps, my system is a sealed S plan, with a Worcester Bosch 24ri, my cylinder is an indirect thermal store so needs to get to 75c, i deviated from the install instructions only in that it has a 22m feed but only 15mm return (existing pipes), it heats up to temp no problem though.
Question 1:
Question 2.
Question 3.
