Servicing a Aga
1 Jun 2008
Sussex
I have just moved into a house with a aga, please can someone tell me how to give it a service, cant be to hard, I can send photos if needed, its oil fired.
So are you experienced with boiler servicing and have a flue gas analyser?
Tony
Agiole - What would you do the a flue gas analyser on an oil fired AGA then ...do tell cos I don't know!! :? :? :? :? :? :?
If you think a FGA is an asset when working on an AGA then you have clearly never worked on one !! :roll:
Nobody said it was an asset,just stating the obvious of what a Flue Gas Analyser does. BTW I dont work on steam engines either. :roll:
Unless it's forced draught gas fired.(which in this case it isn't).
You need to tell us which AGA it is.
A flue gas analyser can check the combustion of any hydrocarbon fuel.
