IDEAL ISAR HE 30 BOILER
22 Nov 2010
Liverpool
bOILER AROUND 3 YEARS OLD NOT WORKING. HEATING WILL NOT COME ON BUT WATER IS FINE. TRIED TURNING IT ON/OFF ETC ETC...CODE FLASHES UP Hb or H6. ANYONE HAVE ANY IDEA WHAT COULD BE WRONG WITH IT.
CHEERS
H : b relates to an issue with the reset button, you will need a new user control fitted.
Try turning the power off then leave for 30secs and turn back on then press the reste and if it still does not work replace the user control.
Part# 173533
JJ
Thanks for that info including the part number. I can get this online for around 60 quid.....can it be replaced easily or do I have to get an engineer to fit it.
Frances
Part# 173533
you have got to work for warmsure getting that part number at this time!!!
JJ
No dont work for them I can get the part off a spare part website ..... do I still need an engineer to fit it?
F
Part# 173533
JJ
Maybe :)
F
Its an easy fit but as many will probably say on here that the Ideal Isar is far from straight forward.
JJ
Frances
i'd be very very very surprised if that is the only part you need if indeed you need it at all!!
try £175 for the part you really need!! robbin barstewards!!
Frances
:) you are right, all H:b i have had though have only been the User Control.
JJ
CHEERS
Hi
My Ideal Isar boiler went down with that message today. I cleaned the electrical connector plug leading into the control unit (where the reset and heating dials are), as it was slightly furred-up, and the boiler works again.
***fingers crossed***
Next step is to take out a cover policy as there's 2ft of snow in Sheffield and it's bloody cold!
Good luck
Ian
Also available for around £30/£40 all-in via eBay.
Mathew
