IM THINKING OF HAVING A NEW KITCHEN INSTALLED ,BUT WAS TOLD TO UPGRADE THE MAIN FUSE FROM 60 AMP TO 80TO100 AMP ,DO I REALY NEED THE UPGRADE AND WHY?,,,,,,CAN ANYONE HELP!!
riveralt";p="1809209 said:IM
............ because they will have to increase the fuse size on the two neighbours who share your supply.
What makes you think they need to do anything to the neighbours supply?![]()
AdrianUK";p="1809269 said:IM
It's got 2 zones at 1.4kW, 1 @ 2kW and 1 @ 2-2.6kW.The new "Candy " induction hob runs off a 13 amp plug
Other than the fact that the DNO won't do it for £10, or anything like?£10.00 for a HRC fuse supplied and fitted whats the problem
In otherwords, you have to consider how to rebalance the load across the three phases - so you either increase everyones fuse and or cable size or you leave it alone.
