htg problem
8 Nov 2004
hey guys,
my daughter has a potterton boiler wall mounted not sure of the model, the problem she is having seems to be with the programmer in the summer when she just wants hot water and moves the ch slider to off the boiler stays on the programmer is an ep2000
thanks
Bill
A bit more info would help ie any motorised valves and other system controls for starters.
Could be clock, zone valve microswitch sticking etc etc etc. Time to get a multimeter me thinks.
sorry i dont really know much about the system, i know they dont have a room stat or anything like that and i am not aware of a motorised valve and neither are they, does there have to be a control valve somehwere??
thanks for the reply
Bill
Time to get some one in who does know then!! :wink:
i just thought it might be something that had happened before and someone would know what was wrong ive usually found this forum very helpful some people aren't of course ??
I looked at a system for a mate once who could only get hot water when the central heating was on. I took a pnut and swapped the programmer and that solved the problem. A lot of them now share a universal back plate so depending on the programmers age it could be a plug and play affair.
I am not a plumber so don't know if the controls are integrated into this model of bolier therefore that would not be as straight forward
would you just explain why the heating would stay on if the cylinder stat isnt working ....just trying to understand how the system works
thanks
Bill
