The house has a loft conversion and for one reason or another the pump over pumps on anything over number 1 into the feed/expansion tank.
I've got the filling loop plumbed in, not need to fit the vessel and valve.
I presume it's a case of:
draining the feed header tank and removing pipes, cap the tank's feed at the cold water tank.
Replace the 22mm tee feeding the circulating pump with an elbow to 'remove' the vent pipe and use what's left of the old 15mm tank feed pipe just before the pump to connect to the valve and expansion vessel?
Add an emergency pressure release pipe to outside (curved back toward the wall)
I'm sure it's easier to do that describe...
What's the best way of flushing the system of what must be several years of crud? Don;t really want it getting onto the new valve/vessel...
Thanks,
Neil.
Thanks,
Neil.
