hi guys
sorry for having to post again about a ariston euro combi a23 mffi. on my last post members said my heat ex is proberbly blocked so i asked someone in trade to do a powerflush which he can only do after christmas.
past problem
boiler flamed out in heating and hot water mode
air pressure switch changed and the problem changed to high flame to low flame in quick ocnession once boiler has heated up
the problem has now got worse, when heating is on the pressure rises slowly to 3 bar when on and redcues when boiler is off, so i phoned the same guy to see if he can come out any quicker which he cant and said it is the expasion tank at fault, this was diagnosed after releasing pressure via the pressure releif valve and pumping the expasion tank up to 1 bar and then topping up with water to 1.5 bar. having done this on request i was told the expansion tank is completly knackered and to buy a new boiler.
do this sound right to you guys, my feeling is a power flush would sort this problem out
past problem
