Currently have an external meter box fitted to our property, which, to be honest, is pretty darned ugly. Its of the recessed type.
Now, we are on an 80Amp supply TT earthed, and I am looking to get this changed to TNCS with a 100Amp supply. I have had problems with the house with voltage drop which I strongly suspect is the result of undersized wiring from the overhead cables. with the 40 amp shower running, we are getting a 3% volt drop at the CU isolator. It manifests itself as the LV halogen bulbs dimming when we turn on the shower. I also have the CU located in the same meter box, I need to install a 60A fused isolator (plus associated 2 pole henley blocks) and a second meter for a submain and there is insufficient space.
The property is 300 metres back from the main road. We have gates which are locked when the property is vacant. I am about to apply for the above changes and am looking to request the meter box is moved indoors, to a cupboard on the 1st floor, directly in front of the supply pole and would mean the supply cable would need cutting and routeing through the wall. This would make rewiring the CU much easier, as the house circuit wires are currently routed up the wall cavity (preventing us from having the cavity wall done) from the existing meter box. It will also mean that instead of having 2 SWA cables routed down the wall (to meter) then back up as a 3-metre meter tail from the meter to the new CU location, we can terminate the cabling direct from the pole to the house.
Are there any regs which state that meters cannot be located indoors? My current rental dating back to the 1980s has an indoor meter, apart from issues regarding the supplier having access to the meter for readings? I cant think of any safety issues, and, bearing in mind the meter is currently 200 metres behind electric gate access, its not as if the supplier will have access in our absence anyhow?
