Hi Again.
Problem with (sucking?) air in my system.
I have a system which WAS gravity hot water, it is now fully pumped.
I realise (thanks to this site) that it is piped very badly.
Because of the layout of our nicely decorated house, it is impossible to re-plumb correctly.
There is a gate valve restrictor in the downstairs boiler room for restricting the flow round the DHW circuit. It also I believe acts as a restrictor to the system filling. (Unintentionally).
I am thinking that when the DHW is satisfied and the pump starts for heating, because it cannot suck water in other than through the restriction, it is creating negative pressure in the radiator return pipework and pulling in minute quantities of air. (I have to bleed the system about once a week).
If I moved the gate valve to the alternative position adjacent to the cylinder upstairs, would there be less "suction" "negative pressure" placed on the system?
ie, the "fill" pipe is unrestricted, the only restriction is in the DHW pumped part of the circuit.
EDIT:....Or, looking at the diagram.....would an alternative position be at the top of the coil where it feeds into the cylinder?
Thanks for having a look.
Any other suggestions / tips.
I really don't want to have landing carpets / floors up!
EDIT2:......Would a better idea be to install a dedicated feed / expansion pair of pipes?
I'll have to bite the bullet and lift floors......like this......
Cheers.
Ian.
Cheers.
Ian.
