Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
surely in the first pic, the cf and ov are wrongly position and there will be problems with pumping over or sucking in air.If you think not can you explain.
The first pic was a standard way of doing it with gravity primaries, and the pump return should go into a spreader bar, if the pump is connected to the wrong tapping it will give problems.
The last drawing is the best way, but it needs an auto by-pass valve across one of the MV's.
I know that is how it was done with grav, but times move on and fully pumping that causes probs, If there were 2 returns it might be a dif matter (as the pump is on return that would be awkward)
I've missed out some of the return pipes......
Would this idea work?
You can see space is tight)
(I've left out some of the return pipes for clarity)
Is the "U" bend under the pump OK?
Thanks very much for the diagram.
I'll be sorting this in the summer.
There is NO pump over-run and......
The living room radiator has NO TRV, it is thermostat controlled.
One last thing......
Magnaclean in the bottom of the "U" beneath the pump?
(After a system clean of course)?
