the boiler issue will need a RGI to sort.
It wasn't clear in your response if you tried what I suggested or not!!!!
turn CH and HW to off at the programmer.
Do both the valves shut AND boiler go off?
bu66er, thought you would have been in bed, or down the pub.
ffs, I cant help when all you do is say, "I've done that it works"
eg I said "turn CH and HW to off at the programmer.
Do both the valves shut AND boiler go off?"
you replied, "I did exactly what you suggested and I will add that is what the gas/plumber did when he came and said "I can't fix it - it isn't broken" as it was running OK at the time. "
Both valves open and close - room stat switches on and off (kills boiler etc when off) Both HW & CH off at programmer and both valves appear to close (Remember I am no expert on these) the little motors wirrr and the little lever moves and the boiler goes off. I didnt want all this, one test/check at a time may find the problem, on-off-on-off doesn't help 1 iota.
I really do give up
Steve, your problem really must be quite simple.
I appreciate you may not know and that plumber you does not know but the reality is that its a very simple system and any faults must by deduction also be simple.
Tony
fan keeps running but no heat so I think the system "thinks" it alight and is calling for heat and the pump is running but the main burner is dead.
Steve
if fan runs with no gas alight
dirty fan or housing
faulty aps
faulty pcb
faulty gv
you need a competant gas engineer to carry out a few basic diagnostic tests on boiler
Simple? That's what I thought then it got too cold so I called in an "expert(?)" but before that I tried a bit of logical thinking - I first thought the pump had packed in after 2 years but on checking there it was wirring away merrily as it should... couldn't believe it. Then I thought the tank stat so I turned it up and down and the HW valve opend and closed - well it made a noise so I presumed it was working (and the "expert" said it was working).
Happy new year and if you know a real live expert in West Sussex please tell me who they are.
Steve
