Hi Everyone,
I have a Gledhill Boilermate II thermal store that is about 13 years old now and an Ideal Classic boiler. At some point, I would like to replace the Boilermate with a Megaflo. I'd like to know how much effort will be involved in the replacement. I understand that the boiler would probably have to change too but what I'd like to know is whether most of the work would be limited to the areas around the tank and the boiler i.e. the main pipes are in fact re-usable.
My Boilermate (if I've understood what I've looked at correctly) has a cold feed, an overflow to outside, a central heating output/return and of course a hot water output (all 22mm). Apart from new valves, pumps etc will there be a need to rip up floor boards between the Boilermate and the boiler?
I don't want to start a discussion about the relative merits of thermal stores (vented) vs Megaflos (unvented) vs combis. I have read quite a bit about all three in the last few months
and believe that a Megaflo would best suit my needs.
Many thanks.
Many thanks.
