I would be grateful if anyone out there can help with constant problems I am getting with a British Gas 330+ High Efficiency Condensing Boiler that I had installed by British Gas only a year ago.
Since I had the boiler installed I've had nothing but trouble with getting the house heated to the desired temperature. This has happened several times and follows the same pattern.
The thermostat which is located downstairs in the hall is set to either 22 or 23 degrees nearly all of the time. The heating and hot water are set to come on twice per day - once in the morning, once in the evening.
The heating comes on for a while and heats the house to say 18 or 19 degrees and then goes off. Regardless of how high the thermo is set, it stays off until either
a) the house cools down to eskimo temperatures (OK slight exaggeration)
b) I have to run the hot water for several minutes which is obviously completely inefficient. Then the heating comes on once more
I have had 3 British Gas engineer visits in the past year and this is driving me mad.
Any help would be much, much appreciated
