Plastering Large areas - Technique
i'm finding bouncing around this forum an invaluable source of help/comfort/knowledge so i can see the value of getting to know some other trade folk.
Already got a couple of sparkies in my mobile phone address book, plumber and builder next :wink:
Thanks spongey
a drop of coca-cola into the skim gives u more time.a trick used in america.give it a go
joking aside, i've been told recently that a handful of board adhesive will slow down the set of finish, not sure i believe it though
not joking.adrop of coke mixed into the skim gives u more time.test it in a cuboard.
regardless whether coke works or not...... i lifted this from a bg site
The addition of Plaster Retarders drastically reduces strength, thereby
impairing the quality of the finish work. it may also produce a “dry-out” situation. (the failure of plaster to set before the water essential for chemical reaction evaporates).
jst something i heard.couldnt stand by it.mabye someone has tried it on this site.
is it ok to apply a coat of pva to a new plasterboard wall to slow the skim down from going off
Yes it will give you a little more time as will using Multifinish instead of Boardfinish but it’s not a magic wand for inexperience.
The thread you just hijacked is 18 months old; if you have questions you should post your own thread, you will get a much better response.
