Hi
since it is accepted that under the bath is un zoned could i do the following?
I have my bathroom lights ( 12v down lighters- mains fed with individual transformers) on a dimmer switch)
I know that if the bath light is on a seperate switch it will never get used
so i was intending to tap off the main light feed drop it down through the stud wall ( or failing that just run the cable down the other side of the wall which has a cupboard and through the wall) then could i just fit some baton from wall to walland run the cable with 3 or 5 ceiling roses and some dimmerable energy saving bulbs?
either that or just a long dimmerble fluro light?
would this work ok?
not to worried about the individual lights shining through the frosting as I intend to colour the panels with lighting gel!
thanks all
would this work ok?
thanks all
