Hi Kenny
So, either the tank is empty
Or the valve(s) aren't doing what they should
Or the filter is blocked!
At least we seem to be getting somewhere!
John
Hello again John....yes, perhaps we are getting somewhere?
Oil? The tank is a 2,650 one and it is about 2 thirds full.
I hope the problem is not with valves...and I am going to have another gentle go to clean the filter after my lunch.
At least I know it cannot be a freeze or something in the oil pipe line....otherwise I guess at least a reasonable amount of oil would have come out of that pipe.
In the meantime....it may give some amusement to some if they have nothing better to do! to read the below E. mail I have just sent to Worcester.
Best Regards
kenny.
The Manager
Customer Relations
Worcester Bosch
Dear Sir or Madam,
Last Friday 21st January 2011 I had cause to call out your engineer because my Worcester Heatslave Condensing Combination Boiler had gone into 'lock out'. The engineer gave a good try at fixing it and returned first thing on Saturday with a replacement burner and this did not correct the situation either.
Your engineer (Rob) advised me that in his opinion the problem is between the Tiger Loop (the oil tank bottom is around 9 foot lower down than the boiler) and the oil tank. He advised that possibly the oil in the line has frozen, went off in his van, and as far as I am concerned left me in the rap.
In order to try and get some help with this I turned to the very informative Forum
www.diynot.com and my full post can be read at
http://www.diynot.com/forums/viewtopic.php?t=259754&postdays=0&postorder=asc&start=0
In my post a very nice person trying to help gave the following opinion.......
"The problem with using a boiler manufacturer to maintain your boiler is that they stop as soon as the fault is not connected to the boiler.
Worcester in particular have been proactive in trying to get householders like you to sign up with them rather than using the installer or other independent service company like mine, but as soon as the going gets tough they quote some nonsense from the small print and walk away ...leaving the householder in the lurch!!
An Independent Service Company would continue his diagnosis back towards the oil tank and resolve the fault for the client
Most independents can provide break-down insurance (such as Blue-Fin / Aviva, which is more comprehensive than manufacturer;s policies
I would seriously consider who maintains your boiler in future!! hope this helps!! (rant over!)"
So with respect....what do you think about that opinion then?
Even to my know nothing expertise in the Central Heating field what he is saying is pretty obvious and with respect and in my humble opinion is a very serious flaw in Worcester Bosch servicing policy...is it not?
From what I can find out it just might have needed your engineer to use a syringe to see if oil can be drawn up the line.
One thing is for sure.....it cannot now be because of the oil being frozen as we have been well above freezing for days here now.
In the meantime......my Wife and I, who are retired pensioners have no central heating and hot water.
To the point....I think it rather cruel of your Engineer to just up and leave us in the mire like that, where possibly just a few minutes of further investigation may have got the central heating on.
A further observation for me is that possibly....just possibly the fault is after all at the boiler. If it is then how can he check that the boiler is in 100% working order if no oil is going into the burner?
Surely part of his brief should be to have an oil supply. I mean...how can he work on the boiler with no oil? Perhaps he could have used his expertise to achieve that?
Me? I know nothing. But if it does turn out that the problem is indeed the boiler....I am going to be even more of an unhappy bunny than I am now!
Best Regards
Kenny Thain.
P.S. I sent off a similar letter by E. Mail to your service dept last night.....but I have heard nothing back as yet.
