Perhaps she really is an angel and hasn't yet noticed she is one......
on mine that is - V ~ 600.
you need to put the probes between the shower and the bath, or just try anything to anything.
dirty girl, pooh, you smell![]()
Everyone is still alive, until they aren't. Then they stop posting. No-one ever comes on here and says "I did this foolish and dangerous thing, and it killed me." This is called "survivor bias"....applying a risk based approach - the fuse has not tripped, I am still alive and the amount of tingle is in direct proportion to my proximity to the pipes and the amount of water.....
Electricity seeks the fastest way to earth, right? - and that is via me when in the water stream and standing in a pool of water in the bath.
Start here.I did ask in a previous post if anyone knew of a certified electrician in the SG3 area - no-one came forward.
Stop messing about as you have been for 10 days now. Either get the plumber back or get an electrician - we cannot help you here because we cannot do the appropriate tests. You have had more than enough advice on what not to do and yet you continue have baths and showers - to me that makes you a Troll whether you are real or not.Am I real and not a troll.. OK - If I can work out how to get photos on here from the iPhone then I will put some up (but not of me in the shower, that would be wrong!)
That is true, but the issue here isn't one of certification, or the original installer. You need someone to identify the fault(s) and rectify them.I've been on to Building Regs (WelHat council) and they told me that one electrician cannot certify someone elses work
The correct action is the same as it was 10 days ago - get a competent electrician to identify and repair the faults. That means TODAY, not tomorrow or next week.
and/or get a prepaid plan here
http://www.co-operative.coop/funera...lan/?gclid=CMmA8JmO1qYCFQsTfAodag9LXA[/QUOTE]
I hear they are pretty good![]()
