I have a electric oven and gas hob in a property at the moment but the main gas pipe has leaked under the floor so the easiest thing o do would be to replace the hob to electric. I am now going to need a extra socket by oven for the hob. The oven is currently on its own circuit. It has a 32 amp fuse in the consumer unit running to a fuse spare with 100 mm cable, then a 13 amp fuse in the spare running 2.5mm cable to the oven. As I need another socket for hob would this be to change the fuse spare to a cooker isolating socket (see link) then from the cooker isolating socket to fuse spare, then fuse spare to cooker. I understand I may not need the fuse spare as it has a fuse in consumer unit but would this be better, also would a 32 amp fuse be big enough to hold 2 appliance or would it need a 45 amp in consumer unit.
http://www.toolstation.com/shop/Ele...r+Switch+Socket+45amp+Neon/d190/sd2633/p67386
