After some advice. I have recently refurbished by bathroom which included fitting a new tiled floor and amonst other things a new loo.
The toilet went on fine, however I seem to have an issue with water around the base of the pan where it sits on the tiles. From what I can see there is water coming from the bottom of the pan (looks like condensation forming on the underside of the pan and then dripping down the inside of the pan until it hits the tiles.
Is this a normal thing? could it be a leak from the pan itself? I'm positive there are no leaks from any of the connections on the pan. Its bone dry around the back where the connections are.
At the moment I have removed the screws securing it to the floor so am able to slightly lift and put some paper towel under the pan, the water is definetly only around the rim of the pan where is touches the tiles.
Only two things I can think of are
1) Condensation forming on underside of pan due to the cold water within the pan itself (the toilet is fed directly from mains I have no water tank in my house)
2) I have a very very small leak in the pan, though if it was this I would expect to see one area of water not water forming all around the pan where it hits the tiles? Also I have attempted dye'ing the pan water overnight and the residue was not coloured at all (I used herbal tea as only thing I had .... )
Any views? at the moment I'm thinking condensation and thinking maybe to put some mastic between the tiles and the pan to try and prevent it (if I do this I also wont be able to see if it works, so could just end up with a build up of water!)
Any help appreciated, have searched but no'one seems to have this problem!
Andy
Andy
