I've recently moved into a newly built flat and the whole place is kitted out with these:
http://www.eterna-lighting.co.uk/productinfo.asp?product=LEP13
I'm led to believe they are of 'European' standard.
Basically, I am trying to get some lampshades that will fit them! I've looked online for 'European lampshade' and '60mm lampshade' but haven't had much luck. Found a few but they were £20-30. Far too much when I need to kit out the whole flat.
Basically, I have two questions -
1. Am I searching for the wrong thing? Surely I should be able to find more lampshades than I currently am for this size? Or are pendants of this size not really used in the UK?
2. What do I need to be able to use bog standard UK lampshades (e.g. http://www.argos.co.uk/ProductDisplayTRK019?partNumber=9280962
)? I've seen 'reducers' on eBay (http://shop.ebay.co.uk/i.html?_nkw=lamp+reducer&_sacat=0&_odkw=bulb+reducer&_osacat=0&_trksid=p3286.c0.m270.l1313) but they are all different sizes! Going by eye 60mm to 30mm looks about right. But I can't see how exactly these would work? Does it just sit above the main adapter part and the shade just sits on it? How would I get it there, would I need to take off the main adapter part (where the bulb slots into)?
As you can probably tell, I am not clued up on my electrics, so any advice would be appreciated. Need to get this sorted as we are all getting bad headaches from the bright light!
Thanks,
Sam
Thanks,
Sam
