I have stripped the old tiles off around my bath ( only 3 tiles high ), which has pulled off the plaster skim and some of the paper from the board beneath. however not down to the plaster filling. The wall above the tiles was painted, emulsion over various layers of other paint.
- I'm thinking this isn't the best surface to tile on.
I plan to fix a mixer shower over the bath with the pipe work concealed in the stud wall. Or that's what I thought. It turn out that I don't have stud walling.
The walls are made of 3 layers of 12.5mm Plasterboard just stick together. It's been suggesting on some forums that this was how many Housing Association buildings were put up ( much of Hemel Hempstead i'm guessing )
So what are my options?
It it possible to strip the top layer of plasterboard off and replace with new. Does anyone know if this is possible?
As for concealing the pipework - I guess I could channel the pipework into the wall - Possibly fixing a sheet of plywood on the other side of the wall ( kitchen ) to fix shower wall-plate to.
Any advice would be appreciated. Thanks
