Hello
I am building a corner cabinet to cover my fusebox which is at floor level. not having much experience with working with wood i fear i have bitten off more than I can chew.
It wouldnt be such a problem if it was a basic triangle corner cabinet but because it has to incorporate the fuse box i have to build it out abit resulting in a triangle with two points cut off, hope this makes sense?
I have made and fitted corner shelves so I plan to build a frame round the front of them which means I have 2 corners of 137 degrees I have to build round. So my question is what is the easiest way to make a length wise bevel/mitre for the 2 uprights which will form the corner of the cabinet?
I have tried marking it out on the wood and using a hand saw and although one turned out OK im not confident they are all going to be the same as i am not very experienced at this. I have borrowed a circular saw but I fear it is a bit hefty considering the wood I am using is 20mm thick by 120mm wide. Any advise would be much apreciated! I am on a budget so wont be able to afford a table saw!
There is a jewsons nearby, Im wondering if they would cut the angles for me??
