I am installing a Dimplex downflow heater in zone 3 of our bathroom, and am intending to take a spur off the ring main which runs just above our bathroom ceiling down to a fused spur unit then onto a double pole isolator ceiling switch, then on to the heater itself (which only contains a live and neutral as it has a plastic body). However I am concerned about how the earth should be wired. We do not have an RCD/CU only a traditional fuse box - I did wonder if I should use an RCD spur rather than a fused spur in the bathroom, or do I simply terminate the earth in the spur or switch?
I did contact Dimplex who simply said 'contact a qualified electrician'!
