I'm planning to board out my loft space with chipboard, so I can store a load of crap up there, which means two slight alterations to the cabling up there. Since the house has had a rewire and new CU after the latest set of regs came in I have a full set of paperwork certifying it, which includes the cable installation method and I want to make sure it stays valid. I don't have any electrical test equipment except a multimeter and a neon, I'm just a standard DIYer.
First there is a cable that runs across the top of some joists, I would need to unhook it from the light fitting, reroute it through the joists and connect it back up. I'd use the same cable, and it would be the same length, just slightly rerouted.
Second there's a screw terminal junction box, I would replace it with a maintenance free one so I can board over the top and forget about it.
In both cases the cables/junction box are loose on top of plasterboard, and there's rockwool over the top.
TIA
TIA
