Sounds good.
And the 6mm from the Hob and oven to the CCU would be fine even if the entire run from Consumer Unit to CCU is in 10mm.
And as above, a 40amp MCB would be ok?
And given that the Oven at 2.2kw and the Hob at 7.2Kw would then be running in effect off 40Amp would this still be ok?
The only reason i was using the FCU was to give the Hob 13Amp safety instead of the full 40Amps of the MCB.
Last but not least, given that some say ovens can trip RCD's can i run the whole Oven/Hob Radial on an RCBO? or would i have the same trip problems ?
