S
scotteng
Hello all,
customer has an electric hob running from 45amp rated switch, using 6mm cable protected by 40amp fuse! ok yes
but then i find there are two single ovens also run from this circuit, connected to a double 13amp socket, both using 13amp plugs, one oven has a rating of approx 11amp, one 15 amp!! socket has 6mm cable feeding it.
and then i find another double 13amp socket supplying a fridge and freezer, again 6mm cable.
hobs full load is approx 23amp.
what do you think i should do to sort this mess out!! grr to kitchen fitters!
