H
holmslaw
I don't think that is correct, these people make decisions that effect a countries industry
It was explained to me years ago by someone that sat on one of this commitees that their decisions are very much political
Agreed. Perhaps we should start another thread?Apologies to JohnW2 for this apparent hijacking
Don't worry on my account, I can just about still see the wood through the trees! However, I'm not so sure that this essentially political side discussion requires a new thread - a more appropriate forum might be an even better idea!Agreed. Perhaps we should start another thread?Apologies to JohnW2 for this apparent hijacking
lol, well b***er me sideways, you can't get a fuse larger than 13A to go into a plug top?? wot, really ?? I guess every day is a school day.I don't think anyone has got anywhere near suggesting that anyone should contemplate attempting a load greater than 13A on a 13A socket - and, in any event, where would they find a fuse of large enough rating (>13A) to put in the plug?Until then, i'm happy to accept the (perhaps simplistic) rule of thumb that the total load connected to a 13A socket should be limited to 13A. Its not too leftfield an idea and I like it
This whole discussion is about double sockets - and hence the question is whether you would be happy to load both of the sockets in a double socket each with 13A (simultaneously), despite the fact that BS1363 only requires the temperature rise test to be done with a total load of 20A (not 26A).
Indeed, and that's a point I keep making. I strongly suspect that a double socket with 2x13A loads would be no more of a problem than a single socket loaded at 13A, even though BS1363 does not include a test which would confirm that.Until IMHO, 'how it is tested' and 'what it is rated at' are two different things.
Kind Regards, John.
Even that leaves the terminology ambiguous, since it begs the question as to what people in general mean by a 'socket outlet'. You take it to mean the entire thing, be it single, double or triple, but others seem to use it to mean each of the 'sockets' (set of three pin holes) present - and I have to say that I would normally use that latter meaning.My bad, i was a bit sloppy by talking about a 'socket' when what i meant was 'socket outlet' - this could be a single or a double, thats 1gang or 2gang ( or even a triple?).
If things were clear and unambiguous, I think everyone would agree with you. However, these discussions only really exist because of the uncertainty as to what the 'stated rating' of a 2 gang socket actually is. To my amazement, apart from the MK one (which, as above, is unclear), I can't find any manufacturer's specs which even mention 'current rating' - but if you look around this forum, and other places, you'll find many people asserting that they are generally 'rated' at 20A (except for MK ones, at 26A). I think that's probably misguided, since it seems to derive only from the BS1363 test conditions for temperature rise, and I think we can probably agree that test conditions and 'ratings' are not the same thing.Ah, now, the 2x13A loads from one socket outlet thing.
If you have knowledge of the testing requirements of BS1363, then you may decide that it will not be a problem.
If you accept that the 'total load' connected through the accessory should be limited to 13A, then 2x13A (which BTW equals 26A ) is exceeding the stated rating of 13A by 100% (thats double)
No, I wouldn't, and that's why I've said that it would not seem to make safe sense to allow Mr & Mrs Public to have double sockets not 'rated' (safe with) 2x13A, since no-one can expect them to know that there is anything wrong at all with fully loading both halves of a 2 gang socket. You go on to say:You may choose to talk about the duty cycle or diversity of the connected loads, but would you ask Mr or Mrs J. Public to appreciate this aswell?
... but the point surely is that you would have no way of knowing what portable devices the customer (or subsequent occupiers) might decide to plug in at some point in time. You would therefore really have to refuse to ever install double sockets if you felt this was a concern.If i was installing a socket outlet for a customer, and i had knowledge that they intended to connect 26A worth of load to it, i would not advise it at all.
Yes, I have sympathy with that - but we are back to the question of what the 'rating' actually is, and what that embossed '13A' actually means. As I wrote at the time, I'm inclined to agree with you - if what it says on the tin is 13A, then one's inclination is to believe that it means 13A, rather than 2x13A. However, I don't think I ever heard anyone but you suggesting that that embossing really does mean that the 'total rating' is 13A - the lowest opinion about 'rating' I've ever seen expressed in 20A.And as if to go full circle ending where i started - until someone can post a photograph of a standard socket outlet which has something other than 13A embossed onto the accessory itself, i will accept that the max connected load is to be limited to 13A. Very, very simple.
Fair enough. I will do the same.Hi John,
I won't bother quoting and inserting into previous posts as it could get a bit messy to read.
Yes you did. Unless you can tell us of another way in which the EU could implement a ban on the sale of bananas of a particular shape.I did'nt mention any regulation or directive
No - any normal person can see that you're deranged and have no interest in the truth of the things you say.and any normal person can see that my banana comments were very tongue in cheek.
That has nothing to do with your nonsense about bananas.My comments about eu corruption and waste have been well documented by others for many many years.
The regulation or directive which you claim specifies the shape of bananas which may or may not be sold in the EU.So what exactly are you asking me to research?
You have made this assertion, so please go away and find some proof that it's true.European standards are best demonstrated by bananas. Some eurow***er decided on the shape of a standard banana.
Somebody could cultivate the tastiest banana in the world but if it was not the correct shape, it would be banned in Europe. ie crushing innovation and progress.
I think it is everybody's duty to challenge rubbish spouted by people who don't care if it's true or not.Or is it that you feel it is your duty, handed down by god almighty, to fight all euro sceptics with the same zeal as you aggressively attack manmade climate change sceptics?
I may not need to quiz them. Life is too short for me to download the 'MK Catalogue' (~630MB download), but I found the following, posted in December 2009 in the IET forum, purporting to be a direct quote from the MK Catalogue:Maybe you would like to quiz MK about it? Why not let us all know what is said...
Assuming the quote is correct, and remains current today, this therefore seems to confirm your view that ('per embossing') each 'unit' (i.e. each double socket) is 'rated' at 13A (total) - even though that say that testing has confirmed that 19.5A is OK 'for an indefinite period' (although 22.3A is not).All MK socket-outlets are manufactured to comply with BS1363 part 2: 1995 and are rated at 13A per unit. Double socket-outlets have been manufactured and tested to exceed this rating by margin that allows electrical safety and reduces the risk of heat and mechanical damage to components due to overloading. It should be noted that BS1363 part 2: 1995 does not allow double sockets to operate at twice the permissible maximum loading and it should be remembered that double socket-outlets are not manufactured to be able to withstand a 26A load for sustained periods of time.
Research by ourselves and third party organisations has shown that all MK double sockets can safely withstand a continuous load of 19.5A for an indefinite period. Increasing the load slightly will begin to cause heat and mechanical stresses on the components in a relatively short period. Testing showed that a load of 22.3A was sufficient to cause heat stress that would cause a browning of the faceplates and sufficient heat to cause insulation damage to cable cores. A load of 24A for 43 hours was sufficient to cause significant heat damage to the material in which the socket-outlet was situated and within 75 hours sufficient to cause significant damage that would lead to the very real potential of fire.
MK recommend that users of their sockets consult professional design Engineers when designing installations to avoid the possibility of heat and mechanical stress to components and installations caused by overloading of MK socket-outlets.
or to para-phrase 'By using smoke and mirrors to confuse the issue between 'testing' and 'rating' our salespersons like allowing people to believe that our sockets are superior to normal socket outlets for our financial gain, but actually, when you really get down to it, there just the same as any other socket and as such we will actually rate them the same.'I may not need to quiz them. Life is too short for me to download the 'MK Catalogue' (~630MB download), but I found the following, posted in December 2009 in the IET forum, purporting to be a direct quote from the MK Catalogue:Maybe you would like to quiz MK about it? Why not let us all know what is said...
indeed, it does.Assuming the quote is correct, and remains current today, this therefore seems to confirm your view that ('per embossing') each 'unit' (i.e. each double socket) is 'rated' at 13A (total)
lol, if thats an open question to all thats fine, but if it were directed at me, you may deduce from my posts here that i do not need to ask them anything as yet again i'll say that to me, its as simple as '13=13', nothing more- even though that say that testing has confirmed that 19.5A is OK 'for an indefinite period' (although 22.3A is not).
Why they chose to 'rate' their product at 13A, when their tests indicate that 19.5A is OK indefinitely, is something you would have to ask them!
risk has not be obliterated, it has been assessed and controlled, maybe thats what has happened in this case?I agree with your view that it's pretty (probably very) unlikely that anyone would plug two 'long term' full loads into one double socket. However, since it's not impossible, I'm surprised that our risk-obsessed society does not feel it necessary to at least tell/warn users about this
im not sure i believe that, i think a lot more people than you give credit to will accept the whole '13=13' thing. Nevertheless, i doubt theres any way to prove or disprove this- since virtually none of them will be aware
but if the user accepts that 13=13, then why would they need constant reminders of this?- particularly given that MK say their tests indicate that 24A for 75 hours "would lead to the very real potential of fire" . The embossed "13A" is obviously useless in this regard, since the homeowener would have to dismantle socket outlets to see it!
o? what examples are you thinking about? I imagine that when you buy electrical accessories from a DIY shed, theres a little slip of paper (or the packaging) included, somewhere on that paper there will be somekind of disclaimer, whereby the purchaser is instructed to consult an electrician, or something similar, so warning has been given. Sparks buying kit from wholesalers probably wouldn't get that same warning as they would probably be deemed competent enough not to need telling how to count to 13.There is plenty of precedent for users/consumers to be 'warned' about risks at least as low as this one!
no offence John, but i think you need to turn down the magnification on your microscope, otherwise you'll worry yourself to bits over every little non-problem you encounter. Now, life is waayyyy too short for that!This does all make me wonder about single sockets, since I still find it hard to believe that a double one is significantly different. If 22.3A (e.g. 11.15A x 2) causes damage to a double socket, then I have to wonder whether a single one should be rated at 13A.
Kick it off one night before you go to bed.I may not need to quiz them. Life is too short for me to download the 'MK Catalogue' (~630MB download),
Interesting - I'll check mine later, because...but I found the following, posted in December 2009 in the IET forum, purporting to be a direct quote from the MK Catalogue:
is complete b******s....It should be noted that BS1363 part 2: 1995 does not allow double sockets to operate at twice the permissible maximum loading...
