Hi Our house was built in 1904 when we brought the property there were signs of movement in the upstairs bedroom because of a crack in the internal wall. The survey said it was cosmetic but it has got alot worse it now goes diagonally down the wall from the top corner to the bottom middle of the wall. The crack in some parts is about 6mm and you can see in to the room behind. Can I buy some sort of fix to stop it getting worse or should I get a stuctural engineer to take a look. How much would this cost? Forgot to say the wall is brick and breeze blocks, cover with plaster.
Thanks Paul
Thanks Paul
