Vaillant boiler trouble!
4 Apr 2011
Cleveland
I have a Vaillant 824/624 turbo max, problem is when the ch on and i run hot water this disconects the ch but hot watrr stays on ie the hot water light still flashes. The only way to reactivate ch on, is to unplug the wires. Ie you want hot water reconect the wire ch unplug wire. I had a new mb fitted a water sensor fitted a new control panel to no avail. Considering a new boiler, unless some1 can give any hint to what problem could b. Thanx :!:
Try turning the cold water isolator valve off under boiler if this stops it u may have a leak on ur hot water circuit or if u got a dripping tap an the warmstarts on the it won't switch back to heating
:D Bunnyman done what u said, look like it could be leak in hotwater system. Having it checked today. Hope it not a major job. But thanx
