scraping back
  • Thread starter Thread starter plstering
  • Start date Start date
yer its fine on sand and cement m8 **** easy l
eave it abit longer befor ruiling off
soo it meens you can get a bit more on or clean up or what i
do is go nd bitch a the labs for taking so long :D
haha i like it mate.
i saw a 2 man team rendering a few months back and one of them had a normal 6ft rule and the other had the h frame in your first vid you posted and the h frame guy just made it look soo much easier to do than the normal rule, the movement and versatility and ease of use just seemd soo much better with the h rule
i used too have a (h) ruile till some tw@t nicked it
used it on the lot from hardwall s/c bonding the lot
now the thing with using a (H) ruile is your not just flattening in you can scrape it back if you loose it when laying on big sets
i use a plane too one s/c/hardwall
http://www.pftcentral.co.uk/1stopshop/product.php?id=279
refina sell the best ones
and i use this on s/c and mono
http://www.pftcentral.co.uk/1stopshop/product.php?id=277
theres just some tools that will save your life these are just some
iv lost it on big wlls befor and used this kit and its worked for me
rember using a toth scraper on a s/c week befor xmas man thats was cold.
i was there a 8pm trying too rub up 15m2 on extention
halogen lights on trying too get it finished so i can work on the hoer right
use the next day got the hump in the end and went home thinking that id be able too finish rubing up in the morn yer right
got in the next morn too stiff too rub up
so i ran the toth scraper over it and it looked the tites
it gives you a honey cone finish like mono
so i did the rest like it turd out nice realy nice
you can see what sort of back ground you can get way with scraping back
haha jon you keep showing me these tools ans my shopping list gets bigger and bigger.
ive done a bit of mono before not loads but enough to give me the gist of it but i was working with somone who does it all the time and i just used thier tools for the job.
i like that idea though on normal s/c lay it on rule it offf roughly then come bk next day and scratch it back then i spose once its painted itll give people the illusion that its mono and that the client spent alot of money getting it done specialy, when really it was bog standard render.
you only scrape it the next day in the winter m8
if you can scrap it same day in the summer
you need too get it flat like youd be rubbing up with sponge
you can leave it like crap if its mono co its esyer too scrape back
as for s/c sraped looking like mono it does
worked on a DPC band under the drip beds on a job
it was dyed render (red) never agen looked like mono in the end but
it turned all me tools red and the mixer too fooking nasty gear
I only scrape s/c now as it cuts your finishing time in half
and you let the lab do do a bit too
(one up one down)
if u realy want too smash a job out and get the m2 on use weber (OCR)
mixs like plaster with a wisk lay it on ruile it off rub it up sorted
and its one coat gear
if its really bad brickwork though you would have to do 2 coats though wouldnt you itd be a nightmare other wise, the little bit i did was only bout 20 m2 and it was 2 coated as it was on a house that had original hacked off and the brickwork was in a right state. i was following the other spreads work and advice did look nice though and i did like the speed of the mixing and laying on the pre bagged stuff.
i saw a vid on you tube where some guys made a company sign out of webber and coloured webber, looked the nuts at the end, might have to do one my self i reckon that would pull in some nice jobs if your doing a nice render job you can screw it to a wall for everyone to see.
thats on the tommys top tips m8 iv done it lookes good m8
its just the mixed gear with paint is a bitch too get right and not too make a mess of it iv done my irms name
you stay off im signage :evil:
lol
i see it first
as for 2 coating yer mite have been rend-aid the pral M or OCR
or even Krend
you can get base coat for mono m8
thats it mate tommys top tips haha, its a nice idea i will have to do one though just so that i can say ive had a go at it, if it looks pukka then outside jobs it goes, macca and itll go in the skip haha itll be fairly simple its only got to be blue and white
weber pral M / Krend £20 each give or take
£10 maybe for paint
ply wood out the skip
im gonna get me bro to make me all the letters of the alphabet at his joiners shop then i can make what ever signs i want be nice to do it for clients aswell a few people i work for are arrogant enough to have thier names etched into thier new render work i will be doing haha should be worth a shot.
the x factor sign they did was pukka aswell mate did you see that one
tell you what m8 it is the tits with all them lights too
as for the alphabet m8 how much wll he charg me for a set bud
