Can someone advise me re concrete flooring please. The ground i propose to build my extension off is currently concreted. It is below the internal floor level but not sure if it is low enough to lay the 50mm sand, dpm, 50mm insulation, 100mm concrete, 25mm screed. As you'll understand i want the floor to be level with my other internal floor levels not higher.
I'm guessing the current difference is around 15cm max. I will check this when i get home and will post exact.
If it is 15cm could i get away with not digging up the floor by minimising the upper layers of flooring. i.e sand concrete screed.
I just want to be sure. many thanks.
