hi guys...iv'e been told that my 2008 ford fiesta titanium needs new front discs and pads. the milage is 14,900. i don't think the car should need these at that low milage. any thoughts.....
mickcoulson
mickcoulson
thanks john, but the car gets used every day, i was there when the guy said it needed new pads, but from what i saw the pads looked to be at least 1/4 inch thick ( i'm a feet and inches bloke ) mickAt that mileage Mick there's no way the pads would be worn out, but there is a good chance that the discs have got a good rust covering on them, which is causing the concern - especially if the car has been standing around a bit.
I have to say, the discs can't be successfully cleaned up, and you wouldn't use old pads with new discs!
John![]()
Burnerman";p="1993115 said:Although the density of pads and discs must vary to some degree, the fact that we now have to use asbestos free pads is a great contributor to disc wear. The good side is that new ones are cheap as chips anyway so long as you steer away from the main dealer network. Nissan are no different from any other manufacturer here.
Have a look at the deposits on your wheels when you wash the car - as well as the usual pad dust you'll find tiny rust particles that come from the discs. Its also these that happily stick into your paintwork!
John
iv'e noticed john when i wash the car the front alloys are nearly black
mick
