Hi all.
I really hope someone can help me.
I've been having a nightmare with my bath (to the point where a patch of kitchen ceiling fell down).
I had a real cowboy botch my new bathroom, and he didn't seal the space between the tiles and the top of the bath properly so that my shower leaked. I was so upset, I couldn't face getting him back to fix the job, as he already had mentioned to me that I might need to put a bath trim over the joint if it doesn't work. (Of course he didn't fit a proper one behind the tiles at the time).
I've tried to put one of those plastic bath trim's around the bath that you can buy from B&Q, and silicone it in place myself.
It worked for awhile, but when I came to clean the bath and get the soap scum off, the silicone just peels off and comes away if you're not careful. This happened in a small spot away from the shower end, so I pushed it back in and made a note to re-silicone soon.
But ... I think that the corner of the bath must have also been leaking for awhile without my knowledge (hence the ceiling coming down).
I feel like the bath is tilted oddly as the water pools in the corner and cant drain away well, then is getting in any cracks in the silicone. But that could just be me thinking it's worse than it is.
I really need to try and fix it myself as I've no money to get someone in.
So if I pull out the old sealant around the trim, shall I just go ahead and re-seal with some top of the range flexible sealant?
Is it possible to layer the sealant up plenty in the corner to help maintain the seal?
And how come it pulls straight off the bath when I go to clean it? Was it bad quality sealant before? Pretty sure I used Unibond stuff.
I know I need to fill the bath before sealing, and I did that last time. Just fed up that I seem to have failed at sealing it.
Can I really go to town with the silicone sealant and slap it on as thick as I like in the corner etc to try and stop this happening again? Build it up a bit like?
So upsetting to have a plumber wreck your bathroom dream that you've saved up for. Hope someone has some tips for me.
