G
gasafengineer
And the way they render the output non-linear with temperature difference?
Water flow rate is non-linear , water flow temperature is near linear.
15-20% of the difference between band d and a; not 15% of the total. If you're so good at German, how come you didn't pick that up?Viessmann quote 15%, if you can understand German and read test.de, they also quote more than 15% for WC.
In reality, the saving is not even that. Provided the installation was designed and installed properly, the return temp is about 20 degrees lower than the flow. Therefore, wc only makes a noticeable difference when the flow temperature is above 75, and virtually nothing below 70. That in turn means, that the wc will not do anything for about 55 minutes out of the hour that the heating is on, unless the boilerstat is screwed up to max. If the boiler stat is set below 75, the wc will do virtually nothing to save money at any time because the cycle will only bring the return temperature near the 55 for a few moments before the boiler clicks off.
If you are such a clever engineer, how come you did not pick that bit up?
I really doubt that. Suppose you can't tell us which document exactly, could you?....Just for clarity , room temperature values of around 20k are recomended by CIBSE ...
So he added an extension, changed his boiler from band d to a or b, and whilst the gasprices rose by about 20%, his bills plummeted despite the fact there was more house to heat.A neighbor took out an 8 year old economical conventional boiler with a copper heat exchanger and fitted a new condensing boiler and put in WC as well. He was doing an extension .... His gas bills dropped like a stone...
All I want is a reliable boiler but still confused.
I was firstly recommended by the repairer to my Alpha combination boiler that is was uneconomical to repair, and that the Baxi duo tec 33 was a good boiler to replace it with, but I have read that they break down quite regularly, so this as put doubt in my mind. on this site I have been recomended viessman vitodens 200, and also have read that vaillant is a reliable boiler and also worcester greenstar
I may not have explained my requirements correctly I live in a detached house whith just my husband and I living there. I said with 2 bathrooms but one has a bath the other only has a shower that is electrically heated, then there is kitchen, utility room, liiving room, dining room, study, conservatory and 3 bedrooms, most rooms have one radiator except living room 2, conservatory 2, and kitchen 2
I want a reliable boiler that is not going to break down every winter as my alpha has done,
Bar a few really bad ones ( personally I would never install an Ideal unless I really hated the customer ) it does't make that much of a difference compared to how good the guy is that will install it.I want a reliable boiler that is not going to break down every winter as my alpha has done, are any of the above boilers ok or any other suggestions
I design my systems to the requiements of the client.
