I have a problem. Please forgive me if I can not describe it in a pro- way.
My old house has a toilet with separated cistern and toilet pan. A tube connected the cistern and the toilet pan for flashing. The drain hole is on the floor. A 90 degree bend drain connector was used.
Now, I have to install a new one-piece toilet, i.e, the cistern and the toilet pan are fixed together. In order to chose one which fit the drain hole position, the important data is the distance between the edge of the outlet and the wall(back of the cistern). So when it is installed, the cistern will be back the wall without gap. However, it is hardly to find any information of it. There are some flexible pan connector can be bent 90 degree. But the minimum distance it needs is about 20cm. I cannot find the toilet with this distance between the outlet edge to the back of the cistern.
Any professional plumbers or good DIYers got good ideas?
I hope I explained it clearly.
