- Joined
- 25 May 2011
- Messages
- 8
- Reaction score
- 0
- Country
I'm looking for advice on the best way to upgrade my central heating system. We live in a two story house with the boiler, pump and controls downstairs and the h/w cylinder upstairs.
The current system is open vented but without an independent hot water circuit (or cylinder stat for that matter). There is a tee from the boiler flow, one branch goes directly to the cylinder, the other to the C/H via a zone valve, therefore I can have hot water only but when the central heating calls for heat the flow from the boiler still circulates through the cylinder. Ideally I'd like a fully independent setup to save some money and stop the h/w getting too hot.
So, first thoughts are simply put another valve on the cylinder circuit but, and here's the problem, the feed and expansion is connected via a tee just before the pipe goes into the cylinder. I can't fit a valve before this tee as I'd turn my system into a sealed one with predictable results!
Can I put a valve on the cylinder return circuit without encountering any problems? - I'm worried about overrun or drawing in air from the feed and expansion pipes.
I appreciate the current system is far from ideal as the feed and expansion should have been fitted before the pump - I expect it was plumbed the way it was originally to save time and effort - this was easily 30+ years ago and the pipework is far from accessible now.
Any and all help/advice gratefully accepted
