Fuses behind integrated appliances is a dumb idea. All isolation and fusing can be on the grid switch panel.
What about a 15 amp socket ( non fused plugs) behind the appliance provided there is a fuse ( FCU ) in the feed to the 15 amp socket ?
Indeed. I said that the grid switch arrangement described by johnsville was 'essentially' the arrangement I have in my kitchen. What you now describe is more-or-less exactly the arrangement I have.There is no need for the FCUs. Have a fuse module after the DP grid switch (located next to it) and remove the fuse plug on the appliance wiring directly. Fuses behind integrated appliances is a dumb idea. All isolation and fusing can be on the grid switch panel.
I do have some ('silly') reservations about the appliances being hard-wired (no plugs), and am not sure I would be comfortable suggesting that for anyone else (e.g. silly though it may be, I wonder if it might contravene some manufacturer's instructions, and thereby be used as an excuse for invalidating a warranty).
In a sane world, there would obiously be no issue. However, some instructions certainly say that the appliance in question should be supplied via a a BS1362 plug fitted with a specified size of fuse. There is seemingly no limit to how much wriggling some companies will do in attempts to get out of liability for warranty and insurance claims, and invoking the fact that the instructions have not been followed to the letter is a common ploy. As you say, one hopes that a court would see that as nonsense, but (not the least because of hassle and cost) such matters very rarely get to the courts.How can it? Look at the instructions. They never state what the electrical connection is. Only that it must meet current regs, etc. Direct wiring of integrated appliances is common.I do have some ('silly') reservations about the appliances being hard-wired (no plugs), and am not sure I would be comfortable suggesting that for anyone else (e.g. silly though it may be, I wonder if it might contravene some manufacturer's instructions, and thereby be used as an excuse for invalidating a warranty).
Again I agree; I have essentially that very arrangement in my kitchen. Mind you, it gets pretty crowded inside the grid switch backbox.
Tell me about it!![]()
I've got a 6 way grid and it has:-
It was a PITA to loom nicely
As I've said, I do avoid this in my kitchen but I have to say that (provided there is an accessible means of isolation, such as grid switches), I don't really think that the fuses in plugs behind appliances is really as much of an issue as many people seem to think ....As for sockets behind appliances in inaccessable locations, well that's just fool hardy and even if acceptable to some (it's not !) simply means hassle when / if a plug fuse fails.
I realise it can't really be done, because some people would abuse them dangerously, but in this sort of situation it's a bit of a pity that 13A plugs without fuses (or a 'solid' connection to replace the fuse) are not available
So have I. I've also seen far more solid conductors than than put into the fuse holder of a 3A plug, for the same reason. Whilst it makes good engineering sense in the specific situation we are talking about, the scope for (deliberate or unwitting) abuse of any such technique is obvious.I have seen a 13A fuse with wire wrapped around the fuse in an inaccessible socket after a FCU.I realise it can't really be done, because some people would abuse them dangerously, but in this sort of situation it's a bit of a pity that 13A plugs without fuses (or a 'solid' connection to replace the fuse) are not available![]()
In what way would a "13A plug" without a fuse be better than a 15A BS 546?I realise it can't really be done, because some people would abuse them dangerously, but in this sort of situation it's a bit of a pity that 13A plugs without fuses (or a 'solid' connection to replace the fuse) are not available - since it's not ideal to have to turn back the clock a few decades and, as bernardgreen suggested, use 5A or 15A plugs/sockets.
Well, the 'silly' (but conceivably important) answer is that MIs often say that an appliance should be fitted with a BS1362 13A plug! In engineering terms, it would not be better,provided (as per the context being discussed here) the socket was pretty inaccessible and the plug rarely removed from the socket - but if it were accessible, then the shuttering and shrouding would presumably represent a degree of betterness.In what way would a "13A plug" without a fuse be better than a 15A BS 546?
What you propose, or wish existed, would not be BS 1363 compliant plug.Well, the 'silly' (but conceivably important) answer is that MIs often say that an appliance should be fitted with a BS1362 13A plug!
Start looking for some 2nd hand portable x-ray machines....In engineering terms, it would not be better,provided (as per the context being discussed here) the socket was pretty inaccessible and the plug rarely removed from the socket - but if it were accessible, then the shuttering and shrouding would presumably represent a degree of betterness.
Interesting. I think these 'red plugs' must have appeared 'after my time'. I've had a lot of dealings in the past with portable x-ray machines but, IIRC, they used large 30A plugs, the sockets for which are (or. at least, were!) to be found all over hospitals.Start looking for some 2nd hand portable x-ray machines....![]()
