Advice required please
I need to change the main stopcock in the house as it has totally seized, i used it around 15 months ago and struggled to use it then so i do really need to change it.
The pipe comming into it is 22mm not sure if its copper and other end is 15mm to copper pipe it also has two entrys at both left and right side, the left side is capped off and the right is to drain the system
My question, im looking at just changing the main middle part where the handle is as this would be far easier
Do they come out easy and secondly are they a bog standard size for replacement
Cheers in advance
Cheers in advance
