Hi all
I need to double one of my floor joists, have no problem with fixing into the wall or with bolting it to the old joist.
However, about 1 ft from the internal wall side there are 5 different holes in the existing joist, each around 4" from the last one. So first hole is about 12"from the wall, second hole is about 16"from the wall etc.
Two of these holes run through the centre of the joist and the other ones are at various heights all above the centre.
Each hole has electric cables through it.
I can't remove the cables so is there any feasible way of doubling up the joist please?
What I was thinking of possibly doing depending on whether people think its a sane idea would be to simply cut out rectangles from the top of the new joist, the required width and depth to allow the new joist to slot into place (am fitting from room below) and then replace the cut out rectangles with rectangles cut from a spare bit of joist and glue into the rectangular holes (obviously the original rectangles I cut out will be too small to glue back due to the saw blade thickness)
Does that sound like a sensible idea please?
The joists are only 6x2 and span about 9 ft at a guess (typing this in bed, not going to measure now ): )
Joe
Joe
